[GRASS-QA] GRASS QA: hamish | ./grass6/ps/ps.map/r_paper.c |no clones | 0 monsters | 0 warnings
Wed Nov 15 20:25:12 EST 2006
Hello hamish,
ANALYSIS
ps/ps.map/r_paper.c functions
read_paper (Begins at: 28 Ends at: 99)
Complexity:   |      15 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |      21 |       |      OK |
LOC:          |      72 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-11-15 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      85 |
LOC:                    42 |       190 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
