[GRASS-QA] GRASS QA: martinl | ./grass6/raster/r.surf.fractal/interface.c |no clones | 0 monsters | 0 warnings
Fri Nov 17 13:24:40 EST 2006
Hello martinl,
ANALYSIS
raster/r.surf.fractal/interface.c functions
interface (Begins at: 14 Ends at: 104)
Complexity:   |       4 |       |      OK |
CalledNBR:    |      22 |       |      OK |
LOC:          |      91 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-11-17 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      85 |
LOC:                    42 |       190 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
