[GRASS-QA] GRASS QA: markus | ./grass6/raster/r.surf.fractal/write_rast.c |no clones | 0 monsters | 0 warnings
Fri Nov 17 15:56:42 EST 2006
Hello markus,
ANALYSIS
raster/r.surf.fractal/write_rast.c functions
write_rast (Begins at: 14 Ends at: 68)
Complexity:   |       3 |       |      OK |
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |      10 |       |      OK |
LOC:          |      55 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-11-17 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      85 |
LOC:                    42 |       190 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
