[GRASS-QA] GRASS QA: hamish | ./grass6/display/d.grid/plot.c |no clones | 0 monsters | 2 warnings
Sat Nov 18 06:45:32 EST 2006
Hello hamish,
ANALYSIS
display/d.grid/plot.c functions
plot_grid (Begins at: 13 Ends at: 102)
Complexity:   |       7 |       |      OK |
ParamNBR:     |       5 |     * |         |
CalledNBR:    |      36 |     * |         |
LOC:          |      90 |       |      OK |
metrics are OK
plot_geogrid (Begins at: 105 Ends at: 227)
Complexity:   |      11 |       |      OK |
CalledNBR:    |      49 |     * |         |
LOC:          |     123 |     * |         |
metrics are OK
init_proj (Begins at: 233 Ends at: 289)
Complexity:   |       6 |       |      OK |
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |      25 |       |      OK |
LOC:          |      57 |       |      OK |
metrics are OK
get_ll_bounds (Begins at: 295 Ends at: 390)
Complexity:   |      13 |       |      OK |
ParamNBR:     |       7 |    ** | Warning |
CalledNBR:    |      12 |       |      OK |
LOC:          |      96 |       |      OK |
at least 1 values are close to an outlier please consider revising code
check_coords (Begins at: 397 Ends at: 462)
ParamNBR:     |       8 |    ** | Warning |
CalledNBR:    |      15 |       |      OK |
LOC:          |      66 |       |      OK |
get_heading (Begins at: 469 Ends at: 500)
Complexity:   |       9 |       |      OK |
CalledNBR:    |       4 |       |      OK |
LOC:          |      32 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-11-18 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      86 |
LOC:                    42 |       190 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
