[GRASS-QA] GRASS QA: brad | ./grass6/lib/gmath/la.c |no clones | 0 monsters | 0 warnings
Sun Nov 19 04:36:50 EST 2006
Hello brad,
ANALYSIS
lib/gmath/la.c functions
Clone analysis:
Threshold GRASS6 key metrics values at 2006-11-19 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      86 |
LOC:                    42 |       190 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
