[GRASS-QA] GRASS QA: glynn | ./grass6/general/g.setproj/get_num.c |2 clones ( get_num.c )| 0 monsters | 0 warnings
Sun Oct 1 17:25:55 EDT 2006
Hello glynn,
ANALYSIS
general/g.setproj/get_num.c functions
get_double (Begins at: 6 Ends at: 12)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |       2 |       |      OK |
LOC:          |       7 |       |      OK |
metrics are OK
get_int (Begins at: 14 Ends at: 20)
LOC:          |       7 |       |      OK |
metrics are OK
get_zone (Begins at: 22 Ends at: 37)
Complexity:   |       3 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       3 |       |      OK |
LOC:          |      16 |       |      OK |
metrics are OK
get_LL_stuff (Begins at: 43 Ends at: 81)
Complexity:   |       8 |       |      OK |
ParamNBR:     |       4 |       |      OK |
CalledNBR:    |      12 |       |      OK |
LOC:          |      39 |       |      OK |
metrics are OK
prompt_num_double (Begins at: 83 Ends at: 102)
Complexity:   |       5 |       |      OK |
CalledNBR:    |       6 |       |      OK |
LOC:          |      20 |       |      OK |
metrics are OK
prompt_num_int (Begins at: 105 Ends at: 124)
LOC:          |      20 |       |      OK |
metrics are OK
Clone analysis:
This file has 2 potentially cloned functions:
  prompt_num_int  prompt_num_double
In general/g.setproj/get_num.c clones of  prompt_num_int are:
	general/g.setproj/get_num.c  prompt_num_double
In general/g.setproj/get_num.c clones of  prompt_num_double are:
	general/g.setproj/get_num.c  prompt_num_int
Threshold GRASS6 key metrics values at 2006-10-01 are:
                           | quartile  | limit   |
Complexity (Cyclo):      5 |        25 |      36 |
CalledNBR:               9 |        55 |      80 |
LOC:                    39 |       179 |     252 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
