[GRASS-QA] GRASS QA: glynn | ./grass6/general/g.setproj/main.c |no clones | 3 monsters | 0 warnings
Sun Oct 1 17:25:55 EDT 2006
Hello glynn,
ANALYSIS
general/g.setproj/main.c functions
main (Begins at: 49 Ends at: 615)
Complexity:   |     103 |   *** | MONSTER |
CalledNBR:    |     247 |   *** | MONSTER |
LOC:          |     567 |   *** | MONSTER |
3 metric are OUT OF RANGE!
min1 (Begins at: 617 Ends at: 622)
Complexity:   |       2 |       |      OK |
CalledNBR:    |       0 |       |      OK |
LOC:          |       6 |       |      OK |
metrics are OK
leave (Begins at: 624 Ends at: 626)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       1 |       |      OK |
LOC:          |       3 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-10-01 are:
                           | quartile  | limit   |
Complexity (Cyclo):      5 |        25 |      36 |
CalledNBR:               9 |        55 |      80 |
LOC:                    39 |       179 |     252 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
