[GRASS-QA] GRASS QA: jachym | ./grass6/raster/r.distance/main.c |no clones | 0 monsters | 0 warnings
Mon Oct 2 14:14:50 EDT 2006
Hello jachym,
ANALYSIS
raster/r.distance/main.c functions
main (Begins at: 25 Ends at: 55)
Complexity:   |       2 |       |      OK |
CalledNBR:    |      10 |       |      OK |
LOC:          |      31 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-10-02 are:
                           | quartile  | limit   |
Complexity (Cyclo):      5 |        25 |      36 |
CalledNBR:               9 |        55 |      81 |
LOC:                    40 |       182 |     253 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
