[GRASS-QA] GRASS QA: brad | ./grass6/lib/db/dbmi_base/xdrtable.c |no clones | 0 monsters | 0 warnings
Wed Oct 11 05:10:39 EDT 2006
Hello brad,
ANALYSIS
lib/db/dbmi_base/xdrtable.c functions
db__send_table_definition (Begins at: 6 Ends at: 23)
Complexity:   |       7 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |      12 |       |      OK |
LOC:          |      18 |       |      OK |
metrics are OK
db__recv_table_definition (Begins at: 26 Ends at: 48)
Complexity:   |       8 |       |      OK |
CalledNBR:    |      14 |       |      OK |
LOC:          |      23 |       |      OK |
metrics are OK
db__send_table_data (Begins at: 51 Ends at: 63)
Complexity:   |       3 |       |      OK |
CalledNBR:    |       5 |       |      OK |
LOC:          |      13 |       |      OK |
metrics are OK
db__recv_table_data (Begins at: 66 Ends at: 84)
Complexity:   |       4 |       |      OK |
CalledNBR:    |       6 |       |      OK |
LOC:          |      19 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-10-11 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      85 |
LOC:                    41 |       189 |     264 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
