[GRASS-QA] GRASS QA: brad | ./grass6/lib/db/dbmi_base/xdrshort.c |2 clones ( xdrchar.c xdrcolumn.c xdrdatetime.c xdrdouble.c xdrint.c xdrshort.c )| 0 monsters | 0 warnings
Wed Oct 11 05:10:39 EDT 2006
Hello brad,
ANALYSIS
lib/db/dbmi_base/xdrshort.c functions
db__send_short (Begins at: 6 Ends at: 25)
Complexity:   |       3 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       4 |       |      OK |
LOC:          |      20 |       |      OK |
metrics are OK
db__recv_short (Begins at: 28 Ends at: 44)
LOC:          |      17 |       |      OK |
metrics are OK
db__send_short_array (Begins at: 47 Ends at: 71)
Complexity:   |       4 |       |      OK |
CalledNBR:    |       5 |       |      OK |
LOC:          |      25 |       |      OK |
metrics are OK
db__recv_short_array (Begins at: 76 Ends at: 125)
Complexity:   |      10 |       |      OK |
CalledNBR:    |       7 |       |      OK |
LOC:          |      50 |       |      OK |
metrics are OK
Clone analysis:
This file has 2 potentially cloned functions:
  db__send_short_array  db__recv_short_array
In lib/db/dbmi_base/xdrshort.c clones of  db__recv_short_array are:
	lib/db/dbmi_base/xdrint.c  db__recv_int_array
In lib/db/dbmi_base/xdrshort.c clones of  db__send_short_array are:
	lib/db/dbmi_base/xdrfloat.c  db__send_float_array
Threshold GRASS6 key metrics values at 2006-10-11 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      85 |
LOC:                    41 |       189 |     264 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
