[GRASS-QA] GRASS QA: jachym | ./grass6/lib/gis/verbose.c |no clones | 0 monsters | 0 warnings
Wed Oct 11 05:38:42 EDT 2006
Hello jachym,
ANALYSIS
lib/gis/verbose.c functions
G_verbose (Begins at: 36 Ends at: 52)
Complexity:   |       4 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       2 |       |      OK |
LOC:          |      17 |       |      OK |
metrics are OK
G_verbose_max (Begins at: 59 Ends at: 62)
Complexity:   |       1 |       |      OK |
CalledNBR:    |       0 |       |      OK |
LOC:          |       4 |       |      OK |
metrics are OK
G_verbose_min (Begins at: 69 Ends at: 72)
LOC:          |       4 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-10-11 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      85 |
LOC:                    41 |       189 |     264 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
