[GRASS-QA] GRASS QA: hamish | ./grass6/vector/v.in.ascii/points.c |no clones | 2 monsters | 0 warnings
Sat Oct 14 03:00:09 EDT 2006
Hello hamish,
ANALYSIS
vector/v.in.ascii/points.c functions
is_int (Begins at: 12 Ends at: 22)
Complexity:   |       4 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       1 |       |      OK |
LOC:          |      11 |       |      OK |
metrics are OK
is_double (Begins at: 26 Ends at: 51)
Complexity:   |       6 |       |      OK |
LOC:          |      26 |       |      OK |
metrics are OK
points_analyse (Begins at: 53 Ends at: 207)
Complexity:   |      19 |     * |         |
ParamNBR:     |      11 |   *** | MONSTER |
CalledNBR:    |      39 |     * |         |
LOC:          |     155 |     * |         |
1 metric are OUT OF RANGE!
points_to_bin (Begins at: 209 Ends at: 332)
Complexity:   |      14 |       |      OK |
ParamNBR:     |      13 |   *** | MONSTER |
CalledNBR:    |      51 |     * |         |
LOC:          |     124 |     * |         |
Clone analysis:
Threshold GRASS6 key metrics values at 2006-10-14 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      85 |
LOC:                    41 |       189 |     264 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
