[GRASS-QA] GRASS QA: jachym | ./grass6/raster/r.fill.dir/resolve.c |2 clones ( resolve.c )| 1 monsters | 0 warnings
Thu Oct 19 15:26:48 EDT 2006
Hello jachym,
ANALYSIS
raster/r.fill.dir/resolve.c functions
select_dir (Begins at: 7 Ends at: 31)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       0 |       |      OK |
LOC:          |      25 |       |      OK |
metrics are OK
flink (Begins at: 33 Ends at: 89)
Complexity:   |      12 |       |      OK |
ParamNBR:     |       9 |   *** | MONSTER |
CalledNBR:    |       2 |       |      OK |
LOC:          |      57 |       |      OK |
1 metric are OUT OF RANGE!
resolve (Begins at: 91 Ends at: 209)
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |      30 |       |      OK |
LOC:          |     119 |     * |         |
metrics are OK
Clone analysis:
This file has 2 potentially cloned functions:
  select_dir  flink
In raster/r.fill.dir/resolve.c clones of  select_dir are:
	raster/r.drain/resolve.c  select_dir
In raster/r.fill.dir/resolve.c clones of  flink are:
	raster/r.drain/resolve.c  flink
Threshold GRASS6 key metrics values at 2006-10-19 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      85 |
LOC:                    41 |       189 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
