[GRASS-QA] GRASS QA: jachym | ./grass6/raster/r.flow/calc.c |no clones | 0 monsters | 0 warnings
Sun Oct 22 05:15:52 EDT 2006
Hello jachym,
ANALYSIS
raster/r.flow/calc.c functions
height_angle_bounding_box (Begins at: 85 Ends at: 138)
Complexity:   |       5 |       |      OK |
ParamNBR:     |       5 |     * |         |
CalledNBR:    |      30 |       |      OK |
LOC:          |      54 |       |      OK |
metrics are OK
on_map (Begins at: 140 Ends at: 146)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |       0 |       |      OK |
LOC:          |       7 |       |      OK |
metrics are OK
add_to_line (Begins at: 153 Ends at: 161)
Complexity:   |       2 |       |      OK |
LOC:          |       9 |       |      OK |
metrics are OK
rectify (Begins at: 166 Ends at: 192)
Complexity:   |       6 |       |      OK |
LOC:          |      27 |       |      OK |
metrics are OK
next_point (Begins at: 194 Ends at: 283)
Complexity:   |       9 |       |      OK |
ParamNBR:     |       4 |       |      OK |
CalledNBR:    |      17 |       |      OK |
LOC:          |      90 |       |      OK |
metrics are OK
calculate (Begins at: 289 Ends at: 390)
Complexity:   |       7 |       |      OK |
ParamNBR:     |       0 |       |      OK |
CalledNBR:    |      29 |       |      OK |
LOC:          |     102 |       |      OK |
metrics are OK
main (Begins at: 392 Ends at: 427)
CalledNBR:    |      19 |       |      OK |
LOC:          |      36 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-10-22 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      85 |
LOC:                    41 |       189 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
