[GRASS-QA] GRASS QA: jachym | ./grass6/raster/r.in.ascii/gethead.c |no clones | 0 monsters | 1 warnings
Sun Oct 22 07:34:39 EDT 2006
Hello jachym,
ANALYSIS
raster/r.in.ascii/gethead.c functions
getgrdhead (Begins at: 22 Ends at: 87)
Complexity:   |       6 |       |      OK |
CalledNBR:    |      20 |       |      OK |
LOC:          |      66 |       |      OK |
metrics are OK
gethead (Begins at: 89 Ends at: 244)
Complexity:   |      29 |    ** | Warning |
ParamNBR:     |       5 |     * |         |
CalledNBR:    |      57 |     * |         |
LOC:          |     156 |     * |         |
at least 1 values are close to an outlier please consider revising code
scan_int (Begins at: 246 Ends at: 259)
Complexity:   |       4 |       |      OK |
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |       1 |       |      OK |
LOC:          |      14 |       |      OK |
metrics are OK
extract (Begins at: 261 Ends at: 275)
Complexity:   |       3 |       |      OK |
ParamNBR:     |       6 |     * |         |
CalledNBR:    |       5 |       |      OK |
LOC:          |      15 |       |      OK |
metrics are OK
missing (Begins at: 277 Ends at: 282)
Complexity:   |       2 |       |      OK |
CalledNBR:    |       2 |       |      OK |
LOC:          |       6 |       |      OK |
metrics are OK
file_scan (Begins at: 286 Ends at: 306)
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       7 |       |      OK |
LOC:          |      21 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-10-22 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      85 |
LOC:                    41 |       189 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
