[GRASS-QA] GRASS QA: hamish | ./grass6/raster/r.watershed/seg/do_astar.c |1 clones ( do_astar.c do_astar.c )| 0 monsters | 0 warnings
Thu Oct 26 03:39:37 EDT 2006
Hello hamish,
ANALYSIS
raster/r.watershed/seg/do_astar.c functions
do_astar (Begins at: 8 Ends at: 69)
Complexity:   |       7 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |      23 |       |      OK |
LOC:          |      62 |       |      OK |
metrics are OK
add_pt (Begins at: 72 Ends at: 120)
Complexity:   |       6 |       |      OK |
ParamNBR:     |       6 |     * |         |
CalledNBR:    |      12 |       |      OK |
LOC:          |      49 |       |      OK |
metrics are OK
get_slope (Begins at: 123 Ends at: 136)
Complexity:   |       4 |       |      OK |
CalledNBR:    |       0 |       |      OK |
LOC:          |      14 |       |      OK |
metrics are OK
replace (Begins at: 139 Ends at: 162)
Complexity:   |       3 |       |      OK |
ParamNBR:     |       4 |       |      OK |
CalledNBR:    |       2 |       |      OK |
LOC:          |      24 |       |      OK |
metrics are OK
Clone analysis:
This file has 1 potentially cloned functions:
  get_slope
In raster/r.watershed/seg/do_astar.c clones of  get_slope are:
	raster/r.watershed/ram/do_astar.c  get_slope
Threshold GRASS6 key metrics values at 2006-10-26 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      85 |
LOC:                    41 |       189 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
