[GRASS-QA] GRASS QA: glynn | ./grass6/lib/init/mke_loc.c |no clones | 0 monsters | 1 warnings
Fri Oct 27 19:30:43 EDT 2006
Hello glynn,
ANALYSIS
lib/init/mke_loc.c functions
make_location (Begins at: 11 Ends at: 182)
Complexity:   |      23 |     * |         |
CalledNBR:    |      66 |    ** | Warning |
LOC:          |     172 |     * |         |
at least 1 values are close to an outlier please consider revising code
Clone analysis:
Threshold GRASS6 key metrics values at 2006-10-27 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      85 |
LOC:                    41 |       189 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
