[GRASS-QA] GRASS QA: glynn | ./grass6/visualization/nviz/src/do_zoom.c |no clones | 0 monsters | 0 warnings
Tue Sep 19 08:17:25 EDT 2006
Hello glynn,
ANALYSIS
visualization/nviz/src/do_zoom.c functions
Nstart_zoom_cmd (Begins at: 42 Ends at: 204)
Complexity:   |      12 |       |      OK |
ParamNBR:     |       4 |       |      OK |
CalledNBR:    |      41 |     * |         |
LOC:          |     163 |     * |         |
metrics are OK
swap_os (Begins at: 211 Ends at: 226)
Complexity:   |       3 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       2 |       |      OK |
LOC:          |      16 |       |      OK |
metrics are OK
Create_OS_Ctx (Begins at: 231 Ends at: 355)
CalledNBR:    |      29 |       |      OK |
LOC:          |     125 |     * |         |
metrics are OK
Destroy_OS_Ctx (Begins at: 361 Ends at: 393)
CalledNBR:    |      11 |       |      OK |
LOC:          |      33 |       |      OK |
metrics are OK
init_ctx (Begins at: 398 Ends at: 431)
Complexity:   |       1 |       |      OK |
CalledNBR:    |      12 |       |      OK |
LOC:          |      34 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-09-19 are:
                           | quartile  | limit   |
Complexity (Cyclo):      5 |        25 |      36 |
CalledNBR:               9 |        55 |      80 |
LOC:                    39 |       179 |     252 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
