[GRASS-QA] GRASS QA: jachym | ./grass6/lib/gis/percent.c |no clones | 0 monsters | 0 warnings
Sat Sep 23 15:06:23 EDT 2006
Hello jachym,
ANALYSIS
lib/gis/percent.c functions
G_percent (Begins at: 51 Ends at: 82)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |       1 |       |      OK |
LOC:          |      32 |       |      OK |
metrics are OK
G_percent2 (Begins at: 84 Ends at: 130)
Complexity:   |      10 |       |      OK |
ParamNBR:     |       4 |       |      OK |
CalledNBR:    |       7 |       |      OK |
LOC:          |      47 |       |      OK |
metrics are OK
G_percent_reset (Begins at: 138 Ends at: 144)
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       0 |       |      OK |
LOC:          |       7 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-09-23 are:
                           | quartile  | limit   |
Complexity (Cyclo):      5 |        25 |      36 |
CalledNBR:               9 |        55 |      80 |
LOC:                    39 |       179 |     252 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
