[GRASS-QA] GRASS QA: soeren | ./grass6/raster3d/r3.out.vtk/writeVTKHead.c |no clones | 0 monsters | 0 warnings
Sun Sep 24 12:30:41 EDT 2006
Hello soeren,
ANALYSIS
raster3d/r3.out.vtk/writeVTKHead.c functions
write_vtk_structured_point_header (Begins at: 34 Ends at: 88)
Complexity:   |       6 |       |      OK |
ParamNBR:     |       4 |       |      OK |
CalledNBR:    |      16 |       |      OK |
LOC:          |      55 |       |      OK |
metrics are OK
write_vtk_structured_grid_header (Begins at: 94 Ends at: 109)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |       8 |       |      OK |
LOC:          |      16 |       |      OK |
metrics are OK
write_vtk_unstructured_grid_header (Begins at: 114 Ends at: 127)
CalledNBR:    |       7 |       |      OK |
LOC:          |      14 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-09-24 are:
                           | quartile  | limit   |
Complexity (Cyclo):      5 |        25 |      36 |
CalledNBR:               9 |        55 |      80 |
LOC:                    39 |       179 |     252 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
