[GRASS-QA] GRASS QA: soeren | ./grass6/raster/r.walk/btree.c |3 clones ( btree.c )| 0 monsters | 1 warnings
Mon Sep 25 09:28:11 EDT 2006
Hello soeren,
ANALYSIS
raster/r.walk/btree.c functions
insert (Begins at: 29 Ends at: 87)
Complexity:   |       8 |       |      OK |
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |       2 |       |      OK |
LOC:          |      59 |       |      OK |
metrics are OK
find (Begins at: 92 Ends at: 132)
Complexity:   |       5 |       |      OK |
CalledNBR:    |       4 |       |      OK |
LOC:          |      41 |       |      OK |
metrics are OK
do_quit (Begins at: 137 Ends at: 142)
Complexity:   |       1 |       |      OK |
CalledNBR:    |       3 |       |      OK |
LOC:          |       6 |       |      OK |
metrics are OK
get_lowest (Begins at: 148 Ends at: 178)
Complexity:   |       4 |       |      OK |
ParamNBR:     |       1 |       |      OK |
LOC:          |      31 |       |      OK |
metrics are OK
delete (Begins at: 183 Ends at: 391)
Complexity:   |      25 |     * |         |
CalledNBR:    |      18 |       |      OK |
LOC:          |     209 |    ** | Warning |
at least 1 values are close to an outlier please consider revising code
show_all (Begins at: 396 Ends at: 406)
Complexity:   |       2 |       |      OK |
LOC:          |      11 |       |      OK |
metrics are OK
show (Begins at: 411 Ends at: 430)
LOC:          |      20 |       |      OK |
metrics are OK
check_all (Begins at: 435 Ends at: 445)
LOC:          |      11 |       |      OK |
metrics are OK
check (Begins at: 450 Ends at: 491)
CalledNBR:    |      14 |       |      OK |
LOC:          |      42 |       |      OK |
metrics are OK
Clone analysis:
This file has 3 potentially cloned functions:
  delete  insert  check
In raster/r.walk/btree.c clones of  delete are:
	raster/r.cost/btree.c  delete
In raster/r.walk/btree.c clones of  check are:
	raster/r.cost/btree.c  check
In raster/r.walk/btree.c clones of  insert are:
	raster/r.cost/btree.c  insert
Threshold GRASS6 key metrics values at 2006-09-25 are:
                           | quartile  | limit   |
Complexity (Cyclo):      5 |        25 |      36 |
CalledNBR:               9 |        55 |      80 |
LOC:                    39 |       179 |     252 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
