[GRASS-QA] GRASS QA: jachym | ./grass6/raster/r.coin/inter.c |no clones | 0 monsters | 2 warnings
Tue Sep 26 04:41:39 EDT 2006
Hello jachym,
ANALYSIS
raster/r.coin/inter.c functions
interactive_version (Begins at: 23 Ends at: 146)
Complexity:   |      32 |    ** | Warning |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |      75 |    ** | Warning |
LOC:          |     124 |     * |         |
at least 2 values are close to an outlier please consider revising code
Clone analysis:
Threshold GRASS6 key metrics values at 2006-09-26 are:
                           | quartile  | limit   |
Complexity (Cyclo):      5 |        25 |      36 |
CalledNBR:               9 |        55 |      80 |
LOC:                    39 |       179 |     252 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
