[GRASS-QA] GRASS QA: glynn | ./grass6/lib/gis/paths.c |no clones | 0 monsters | 0 warnings
Wed Apr 4 03:06:07 EDT 2007
Hello glynn,
ANALYSIS
lib/gis/paths.c functions
G_mkdir (Begins at: 17 Ends at: 33)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       1 |       |      OK |
LOC:          |      17 |       |      OK |
metrics are OK
G_is_dirsep (Begins at: 35 Ends at: 50)
Complexity:   |       2 |       |      OK |
CalledNBR:    |       0 |       |      OK |
LOC:          |      16 |       |      OK |
metrics are OK
G_convert_dirseps_to_host (Begins at: 52 Ends at: 72)
LOC:          |      21 |       |      OK |
metrics are OK
G_convert_dirseps_from_host (Begins at: 74 Ends at: 95)
LOC:          |      22 |       |      OK |
metrics are OK
G_stat (Begins at: 97 Ends at: 112)
LOC:          |      16 |       |      OK |
metrics are OK
G_lstat (Begins at: 114 Ends at: 121)
LOC:          |       8 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-04-04 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      87 |
LOC:                    43 |       195 |     272 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
