[GRASS-QA] GRASS QA: glynn | ./grass6/lib/raster/loc_io.c |no clones | 0 monsters | 0 warnings
Wed Apr 4 03:09:52 EDT 2007
Hello glynn,
ANALYSIS
lib/raster/loc_io.c functions
LOC_init (Begins at: 22 Ends at: 56)
Complexity:   |       4 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |      20 |       |      OK |
LOC:          |      35 |       |      OK |
metrics are OK
LOC_open_driver (Begins at: 58 Ends at: 101)
Complexity:   |       1 |       |      OK |
CalledNBR:    |       3 |       |      OK |
LOC:          |      44 |       |      OK |
metrics are OK
LOC__open_quiet (Begins at: 103 Ends at: 106)
CalledNBR:    |       0 |       |      OK |
LOC:          |       4 |       |      OK |
metrics are OK
LOC_stabilize (Begins at: 108 Ends at: 111)
CalledNBR:    |       1 |       |      OK |
LOC:          |       4 |       |      OK |
metrics are OK
LOC_kill_driver (Begins at: 113 Ends at: 116)
LOC:          |       4 |       |      OK |
metrics are OK
LOC_close_driver (Begins at: 118 Ends at: 123)
LOC:          |       6 |       |      OK |
metrics are OK
LOC_release_driver (Begins at: 125 Ends at: 129)
CalledNBR:    |       2 |       |      OK |
LOC:          |       5 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-04-04 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      87 |
LOC:                    43 |       195 |     272 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
