[GRASS-QA] GRASS QA: glynn | ./grass6/lib/psdriver/Raster.c |no clones | 0 monsters | 0 warnings
Fri Apr 6 12:06:47 EDT 2007
Hello glynn,
ANALYSIS
lib/psdriver/Raster.c functions
PS_begin_scaled_raster (Begins at: 9 Ends at: 23)
Complexity:   |       1 |       |      OK |
CalledNBR:    |       4 |       |      OK |
LOC:          |      15 |       |      OK |
metrics are OK
PS_scaled_raster (Begins at: 25 Ends at: 66)
Complexity:   |       5 |       |      OK |
ParamNBR:     |       6 |     * |         |
CalledNBR:    |       7 |       |      OK |
LOC:          |      42 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-04-06 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      87 |
LOC:                    43 |       195 |     272 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
