[GRASS-QA] GRASS QA: glynn | ./grass6/lib/raster/loc_io.c |no clones | 0 monsters | 0 warnings
Sat Apr 7 06:36:35 EDT 2007
Hello glynn,
ANALYSIS
lib/raster/loc_io.c functions
LOC_init (Begins at: 24 Ends at: 58)
Complexity:   |       4 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |      20 |       |      OK |
LOC:          |      35 |       |      OK |
metrics are OK
LOC_open_driver (Begins at: 60 Ends at: 74)
Complexity:   |       1 |       |      OK |
CalledNBR:    |       7 |       |      OK |
LOC:          |      15 |       |      OK |
metrics are OK
LOC__open_quiet (Begins at: 76 Ends at: 79)
CalledNBR:    |       0 |       |      OK |
LOC:          |       4 |       |      OK |
metrics are OK
LOC_stabilize (Begins at: 81 Ends at: 84)
CalledNBR:    |       1 |       |      OK |
LOC:          |       4 |       |      OK |
metrics are OK
LOC_kill_driver (Begins at: 86 Ends at: 89)
LOC:          |       4 |       |      OK |
metrics are OK
LOC_close_driver (Begins at: 91 Ends at: 96)
CalledNBR:    |       3 |       |      OK |
LOC:          |       6 |       |      OK |
metrics are OK
LOC_release_driver (Begins at: 98 Ends at: 102)
CalledNBR:    |       2 |       |      OK |
LOC:          |       5 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-04-07 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      87 |
LOC:                    43 |       195 |     272 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
