[GRASS-QA] GRASS QA: robertoa | ./grass6/vector/lidar/v.lidar.edgedetection/edgedetection.c |no clones | 2 monsters | 0 warnings
Thu Apr 12 13:30:59 EDT 2007
Hello robertoa,
ANALYSIS
vector/lidar/v.lidar.edgedetection/edgedetection.c functions
edge_detection (Begins at: 35 Ends at: 113)
Complexity:   |       7 |       |      OK |
ParamNBR:     |      10 |   *** | MONSTER |
CalledNBR:    |      32 |       |      OK |
LOC:          |      79 |       |      OK |
1 metric are OUT OF RANGE!
Get_Gradient (Begins at: 115 Ends at: 137)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       4 |       |      OK |
CalledNBR:    |       1 |       |      OK |
LOC:          |      23 |       |      OK |
metrics are OK
classification (Begins at: 139 Ends at: 309)
Complexity:   |      24 |     * |         |
ParamNBR:     |      16 |   *** | MONSTER |
CalledNBR:    |      61 |    ** | Warning |
LOC:          |     171 |     * |         |
Insert (Begins at: 311 Ends at: 324)
ParamNBR:     |       5 |     * |         |
CalledNBR:    |       6 |       |      OK |
LOC:          |      14 |       |      OK |
metrics are OK
Insert_Interpolation (Begins at: 326 Ends at: 339)
LOC:          |      14 |       |      OK |
metrics are OK
UpDate (Begins at: 342 Ends at: 354)
CalledNBR:    |       4 |       |      OK |
LOC:          |      13 |       |      OK |
metrics are OK
Select (Begins at: 356 Ends at: 398)
Complexity:   |       6 |       |      OK |
CalledNBR:    |      22 |       |      OK |
LOC:          |      43 |       |      OK |
metrics are OK
Create_AuxEdge_Table (Begins at: 401 Ends at: 434)
Complexity:   |       2 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |      18 |       |      OK |
LOC:          |      34 |       |      OK |
metrics are OK
Drop_Aux_Table (Begins at: 436 Ends at: 445)
LOC:          |      10 |       |      OK |
metrics are OK
Create_Interpolation_Table (Begins at: 448 Ends at: 474)
CalledNBR:    |      14 |       |      OK |
LOC:          |      27 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-04-12 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      87 |
LOC:                    43 |       195 |     272 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
