[GRASS-QA] GRASS QA: martinl | ./grass6/lib/gis/set_window.c |no clones | 0 monsters | 0 warnings
Fri Apr 13 05:35:25 EDT 2007
Hello martinl,
ANALYSIS
lib/gis/set_window.c functions
G_get_set_window (Begins at: 30 Ends at: 49)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       2 |       |      OK |
LOC:          |      20 |       |      OK |
metrics are OK
G_set_window (Begins at: 51 Ends at: 160)
Complexity:   |       8 |       |      OK |
CalledNBR:    |      13 |       |      OK |
LOC:          |     110 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-04-13 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      87 |
LOC:                    43 |       195 |     272 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
