[GRASS-QA] GRASS QA: moritz | ./grass6/db/drivers/sqlite/listtab.c |no clones | 0 monsters | 0 warnings
Fri Apr 13 12:35:16 EDT 2007
Hello moritz,
ANALYSIS
db/drivers/sqlite/listtab.c functions
db__driver_list_tables (Begins at: 20 Ends at: 75)
Complexity:   |       5 |       |      OK |
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |      19 |       |      OK |
LOC:          |      56 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-04-13 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      87 |
LOC:                    43 |       195 |     272 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
