[GRASS-QA] GRASS QA: glynn | ./grass6/lib/gis/ask.c |2 clones ( main.c main.c ask.c )| 1 monsters | 1 warnings
Fri Apr 13 20:44:01 EDT 2007
Hello glynn,
ANALYSIS
lib/gis/ask.c functions
G_ask_new (Begins at: 130 Ends at: 134)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       4 |       |      OK |
CalledNBR:    |       1 |       |      OK |
LOC:          |       5 |       |      OK |
metrics are OK
G_ask_new_ext (Begins at: 136 Ends at: 158)
ParamNBR:     |       6 |     * |         |
LOC:          |      23 |       |      OK |
metrics are OK
G_ask_old (Begins at: 160 Ends at: 164)
LOC:          |       5 |       |      OK |
metrics are OK
G_ask_old_ext (Begins at: 166 Ends at: 188)
LOC:          |      23 |       |      OK |
metrics are OK
G_ask_any (Begins at: 190 Ends at: 194)
ParamNBR:     |       5 |     * |         |
LOC:          |       5 |       |      OK |
metrics are OK
G_ask_any_ext (Begins at: 196 Ends at: 218)
ParamNBR:     |       7 |    ** | Warning |
LOC:          |      23 |       |      OK |
at least 1 values are close to an outlier please consider revising code
G_ask_in_mapset (Begins at: 221 Ends at: 225)
LOC:          |       5 |       |      OK |
metrics are OK
G_ask_in_mapset_ext (Begins at: 228 Ends at: 245)
LOC:          |      18 |       |      OK |
metrics are OK
G_ask_new_file (Begins at: 248 Ends at: 280)
LOC:          |      33 |       |      OK |
metrics are OK
G_ask_old_file (Begins at: 283 Ends at: 314)
LOC:          |      32 |       |      OK |
metrics are OK
G_set_ask_return_msg (Begins at: 316 Ends at: 334)
Complexity:   |       2 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       2 |       |      OK |
LOC:          |      19 |       |      OK |
metrics are OK
G_get_ask_return_msg (Begins at: 336 Ends at: 341)
ParamNBR:     |       0 |       |      OK |
LOC:          |       6 |       |      OK |
metrics are OK
ask (Begins at: 343 Ends at: 592)
Complexity:   |      46 |   *** | MONSTER |
CalledNBR:    |      68 |    ** | Warning |
LOC:          |     250 |    ** | Warning |
1 metric are OUT OF RANGE!
parselist (Begins at: 594 Ends at: 627)
Complexity:   |      10 |       |      OK |
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |       4 |       |      OK |
LOC:          |      34 |       |      OK |
metrics are OK
Clone analysis:
This file has 2 potentially cloned functions:
  G_ask_old_ext  G_ask_new_ext
In lib/gis/ask.c clones of  G_ask_old_ext are:
	lib/gis/ask.c  G_ask_new_ext
In lib/gis/ask.c clones of  G_ask_new_ext are:
	lib/gis/ask.c  G_ask_old_ext
Threshold GRASS6 key metrics values at 2007-04-13 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      87 |
LOC:                    43 |       195 |     272 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
