[GRASS-QA] GRASS QA: glynn | ./grass6/raster/r.colors/main.c |no clones | 2 monsters | 0 warnings
Fri Apr 13 23:50:07 EDT 2007
Hello glynn,
ANALYSIS
raster/r.colors/main.c functions
scan_rules (Begins at: 35 Ends at: 49)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       8 |       |      OK |
LOC:          |      15 |       |      OK |
metrics are OK
rules_list (Begins at: 51 Ends at: 77)
Complexity:   |       3 |       |      OK |
CalledNBR:    |       3 |       |      OK |
LOC:          |      27 |       |      OK |
metrics are OK
list_rules (Begins at: 79 Ends at: 85)
CalledNBR:    |       1 |       |      OK |
LOC:          |       7 |       |      OK |
metrics are OK
find_rule (Begins at: 87 Ends at: 96)
Complexity:   |       2 |       |      OK |
LOC:          |      10 |       |      OK |
metrics are OK
main (Begins at: 98 Ends at: 336)
Complexity:   |      38 |   *** | MONSTER |
CalledNBR:    |      98 |   *** | MONSTER |
LOC:          |     239 |    ** | Warning |
2 metric are OUT OF RANGE!
Clone analysis:
Threshold GRASS6 key metrics values at 2007-04-13 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      87 |
LOC:                    43 |       195 |     272 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
