[GRASS-QA] GRASS QA: glynn | ./grass6/lib/gis/histo_eq.c |no clones | 0 monsters | 0 warnings
Sat Apr 14 19:38:24 EDT 2007
Hello glynn,
ANALYSIS
lib/gis/histo_eq.c functions
G_histogram_eq (Begins at: 12 Ends at: 80)
Complexity:   |      11 |       |      OK |
ParamNBR:     |       4 |       |      OK |
CalledNBR:    |      12 |       |      OK |
LOC:          |      69 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-04-14 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      87 |
LOC:                    43 |       195 |     272 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
