[GRASS-QA] GRASS QA: glynn | ./grass6/lib/gis/color_write.c |no clones | 0 monsters | 0 warnings
Sat Apr 14 19:38:22 EDT 2007
Hello glynn,
ANALYSIS
lib/gis/color_write.c functions
G_write_colors (Begins at: 76 Ends at: 106)
Complexity:   |       5 |       |      OK |
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |      10 |       |      OK |
LOC:          |      31 |       |      OK |
metrics are OK
G__write_colors (Begins at: 108 Ends at: 116)
Complexity:   |       3 |       |      OK |
CalledNBR:    |       4 |       |      OK |
LOC:          |       9 |       |      OK |
metrics are OK
write_new_colors (Begins at: 118 Ends at: 161)
Complexity:   |       9 |       |      OK |
CalledNBR:    |      17 |       |      OK |
LOC:          |      44 |       |      OK |
metrics are OK
write_rules (Begins at: 163 Ends at: 209)
Complexity:   |       7 |       |      OK |
ParamNBR:     |       4 |       |      OK |
CalledNBR:    |      11 |       |      OK |
LOC:          |      47 |       |      OK |
metrics are OK
write_old_colors (Begins at: 211 Ends at: 239)
CalledNBR:    |       6 |       |      OK |
LOC:          |      29 |       |      OK |
metrics are OK
forced_write_old_colors (Begins at: 241 Ends at: 260)
Complexity:   |       2 |       |      OK |
CalledNBR:    |       7 |       |      OK |
LOC:          |      20 |       |      OK |
metrics are OK
format_min (Begins at: 262 Ends at: 275)
LOC:          |      14 |       |      OK |
metrics are OK
format_max (Begins at: 277 Ends at: 290)
LOC:          |      14 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-04-14 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      87 |
LOC:                    43 |       195 |     272 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
