[GRASS-QA] GRASS QA: glynn | ./grass6/imagery/i.class/input.c |6 clones ( input.c )| 0 monsters | 0 warnings
Sun Apr 15 17:07:51 EDT 2007
Hello glynn,
ANALYSIS
imagery/i.class/input.c functions
Input_pointer (Begins at: 21 Ends at: 24)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       1 |       |      OK |
LOC:          |       4 |       |      OK |
metrics are OK
Input_box (Begins at: 27 Ends at: 30)
ParamNBR:     |       3 |       |      OK |
LOC:          |       4 |       |      OK |
metrics are OK
Input_other (Begins at: 33 Ends at: 46)
Complexity:   |       2 |       |      OK |
CalledNBR:    |       5 |       |      OK |
LOC:          |      14 |       |      OK |
metrics are OK
mouse (Begins at: 48 Ends at: 103)
Complexity:   |      12 |       |      OK |
ParamNBR:     |       4 |       |      OK |
CalledNBR:    |       9 |       |      OK |
LOC:          |      56 |       |      OK |
metrics are OK
use_mouse_msg (Begins at: 107 Ends at: 112)
LOC:          |       6 |       |      OK |
metrics are OK
draw_objects (Begins at: 114 Ends at: 178)
Complexity:   |       8 |       |      OK |
CalledNBR:    |      16 |       |      OK |
LOC:          |      65 |       |      OK |
metrics are OK
find (Begins at: 180 Ends at: 202)
Complexity:   |       7 |       |      OK |
LOC:          |      23 |       |      OK |
metrics are OK
select_option (Begins at: 204 Ends at: 216)
Complexity:   |       3 |       |      OK |
CalledNBR:    |       0 |       |      OK |
LOC:          |      13 |       |      OK |
metrics are OK
draw_option_boxes (Begins at: 218 Ends at: 236)
CalledNBR:    |       4 |       |      OK |
LOC:          |      19 |       |      OK |
metrics are OK
visible (Begins at: 238 Ends at: 243)
LOC:          |       6 |       |      OK |
metrics are OK
Menu_msg (Begins at: 246 Ends at: 266)
LOC:          |      21 |       |      OK |
metrics are OK
Start_mouse_in_menu (Begins at: 269 Ends at: 276)
LOC:          |       8 |       |      OK |
metrics are OK
Clone analysis:
This file has 6 potentially cloned functions:
  Input_other  draw_option_boxes  mouse  select_option  find  draw_objects
In imagery/i.class/input.c clones of  select_option are:
	imagery/i.vpoints/input.c  select_option
	imagery/i.points/input.c  select_option
	imagery/i.ortho.photo/photo.2target/input.c  select_option
	imagery/i.ortho.photo/photo.2image/input.c  select_option
In imagery/i.class/input.c clones of  mouse are:
	imagery/i.points/input.c  mouse
In imagery/i.class/input.c clones of  draw_option_boxes are:
	imagery/i.ortho.photo/photo.2target/input.c  draw_option_boxes
	imagery/i.ortho.photo/photo.2image/input.c  draw_option_boxes
In imagery/i.class/input.c clones of  draw_objects are:
	imagery/i.vpoints/input.c  draw_objects
	imagery/i.points/input.c  draw_objects
	imagery/i.ortho.photo/photo.2target/input.c  draw_objects
	imagery/i.ortho.photo/photo.2image/input.c  draw_objects
In imagery/i.class/input.c clones of  find are:
	imagery/i.vpoints/input.c  find
	imagery/i.points/input.c  find
	imagery/i.ortho.photo/photo.2target/input.c  find
	imagery/i.ortho.photo/photo.2image/input.c  find
In imagery/i.class/input.c clones of  Input_other are:
	imagery/i.ortho.photo/photo.2image/input.c  Input_other
Threshold GRASS6 key metrics values at 2007-04-15 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      87 |
LOC:                    43 |       195 |     272 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
