[GRASS-QA] GRASS QA: glynn | ./grass6/lib/g3d/fpcompress.c |4 clones ( input.c georef.c ask.c fpcompress.c )| 0 monsters | 5 warnings
Sun Apr 15 17:07:52 EDT 2007
Hello glynn,
ANALYSIS
lib/g3d/fpcompress.c functions
G_fpcompress_printBinary (Begins at: 22 Ends at: 34)
Complexity:   |       1 |       |      OK |
CalledNBR:    |       1 |       |      OK |
LOC:          |      13 |       |      OK |
metrics are OK
G_fpcompress_dissectXdrDouble (Begins at: 39 Ends at: 56)
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       9 |       |      OK |
LOC:          |      18 |       |      OK |
metrics are OK
G_fpcompress_rearrangeEncodeFloats (Begins at: 72 Ends at: 202)
Complexity:   |      18 |     * |         |
ParamNBR:     |       6 |     * |         |
CalledNBR:    |       2 |       |      OK |
LOC:          |     131 |     * |         |
metrics are OK
G_fpcompress_rearrangeEncodeDoubles (Begins at: 207 Ends at: 361)
Complexity:   |      24 |     * |         |
LOC:          |     155 |     * |         |
metrics are OK
G_fpcompress_rearrangeDecodeFloats (Begins at: 366 Ends at: 492)
Complexity:   |      23 |     * |         |
ParamNBR:     |       4 |       |      OK |
LOC:          |     127 |     * |         |
metrics are OK
G_fpcompress_rearrangeDecodeDoubles (Begins at: 497 Ends at: 648)
Complexity:   |      26 |    ** | Warning |
LOC:          |     152 |     * |         |
at least 1 values are close to an outlier please consider revising code
G_fpcompress_writeXdrNums (Begins at: 655 Ends at: 733)
Complexity:   |       8 |       |      OK |
ParamNBR:     |       8 |    ** | Warning |
LOC:          |      79 |       |      OK |
G_fpcompress_writeXdrFloats (Begins at: 738 Ends at: 749)
Complexity:   |       2 |       |      OK |
ParamNBR:     |       7 |    ** | Warning |
LOC:          |      12 |       |      OK |
G_fpcompress_writeXdrDouble (Begins at: 754 Ends at: 765)
LOC:          |      12 |       |      OK |
G_fpcompress_readXdrNums (Begins at: 770 Ends at: 816)
CalledNBR:    |       6 |       |      OK |
LOC:          |      47 |       |      OK |
G_fpcompress_readXdrFloats (Begins at: 821 Ends at: 832)
LOC:          |      12 |       |      OK |
metrics are OK
G_fpcompress_readXdrDoubles (Begins at: 837 Ends at: 848)
LOC:          |      12 |       |      OK |
metrics are OK
Clone analysis:
This file has 4 potentially cloned functions:
  G_fpcompress_readXdrDoubles  G_fpcompress_readXdrFloats  G_fpcompress_writeXdrDouble  G_fpcompress_writeXdrFloats
In lib/g3d/fpcompress.c clones of  G_fpcompress_writeXdrDouble are:
	lib/g3d/fpcompress.c  G_fpcompress_writeXdrFloats
In lib/g3d/fpcompress.c clones of  G_fpcompress_readXdrFloats are:
	lib/g3d/fpcompress.c  G_fpcompress_readXdrDoubles
In lib/g3d/fpcompress.c clones of  G_fpcompress_writeXdrFloats are:
	lib/g3d/fpcompress.c  G_fpcompress_writeXdrDouble
In lib/g3d/fpcompress.c clones of  G_fpcompress_readXdrDoubles are:
	lib/g3d/fpcompress.c  G_fpcompress_readXdrFloats
Threshold GRASS6 key metrics values at 2007-04-15 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      87 |
LOC:                    43 |       195 |     272 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
