[GRASS-QA] GRASS QA: glynn | ./grass6/raster/r.le/r.le.pixel/texture.c |no clones | 5 monsters | 4 warnings
Sun Apr 15 17:07:53 EDT 2007
Hello glynn,
ANALYSIS
raster/r.le/r.le.pixel/texture.c functions
mv_texture (Begins at: 56 Ends at: 238)
Complexity:   |      32 |    ** | Warning |
ParamNBR:     |       9 |   *** | MONSTER |
CalledNBR:    |      19 |       |      OK |
LOC:          |     183 |     * |         |
at least 2 values are close to an outlier please consider revising code
df_texture (Begins at: 246 Ends at: 587)
Complexity:   |      47 |   *** | MONSTER |
ParamNBR:     |       7 |    ** | Warning |
CalledNBR:    |      85 |    ** | Warning |
LOC:          |     342 |   *** | MONSTER |
2 metric are OUT OF RANGE!
cal_att (Begins at: 595 Ends at: 648)
Complexity:   |       7 |       |      OK |
CalledNBR:    |       1 |       |      OK |
LOC:          |      54 |       |      OK |
at least 1 values are close to an outlier please consider revising code
cal_divers (Begins at: 655 Ends at: 730)
Complexity:   |       6 |       |      OK |
CalledNBR:    |       4 |       |      OK |
LOC:          |      76 |       |      OK |
cal_tex (Begins at: 732 Ends at: 891)
Complexity:   |      24 |     * |         |
ParamNBR:     |      10 |   *** | MONSTER |
CalledNBR:    |      14 |       |      OK |
LOC:          |     160 |     * |         |
1 metric are OUT OF RANGE!
cal_edge (Begins at: 897 Ends at: 1179)
Complexity:   |      35 |    ** | Warning |
ParamNBR:     |      15 |   *** | MONSTER |
LOC:          |     283 |   *** | MONSTER |
read_weight (Begins at: 1186 Ends at: 1239)
Complexity:   |       4 |       |      OK |
ParamNBR:     |       4 |       |      OK |
CalledNBR:    |      15 |       |      OK |
LOC:          |      54 |       |      OK |
metrics are OK
read_edge (Begins at: 1241 Ends at: 1298)
ParamNBR:     |       3 |       |      OK |
LOC:          |      58 |       |      OK |
metrics are OK
find_loc (Begins at: 1300 Ends at: 1319)
Complexity:   |       2 |       |      OK |
CalledNBR:    |       2 |       |      OK |
LOC:          |      20 |       |      OK |
metrics are OK
find_edge (Begins at: 1321 Ends at: 1335)
LOC:          |      15 |       |      OK |
metrics are OK
check_order (Begins at: 1343 Ends at: 1351)
CalledNBR:    |       0 |       |      OK |
LOC:          |       9 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-04-15 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      87 |
LOC:                    43 |       195 |     272 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
