[GRASS-QA] GRASS QA: glynn | ./grass6/raster/r.report/maskinfo.c |1 clones ( input.c georef.c ask.c fpcompress.c g3derror.c padrange.c maskinfo.c )| 0 monsters | 0 warnings
Sun Apr 15 17:07:54 EDT 2007
Hello glynn,
ANALYSIS
raster/r.report/maskinfo.c functions
maskinfo (Begins at: 9 Ends at: 45)
Complexity:   |       6 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |      14 |       |      OK |
LOC:          |      37 |       |      OK |
metrics are OK
reclass_text (Begins at: 47 Ends at: 76)
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |       3 |       |      OK |
LOC:          |      30 |       |      OK |
metrics are OK
do_text (Begins at: 78 Ends at: 93)
Complexity:   |       3 |       |      OK |
CalledNBR:    |       4 |       |      OK |
LOC:          |      16 |       |      OK |
metrics are OK
append (Begins at: 95 Ends at: 102)
Complexity:   |       2 |       |      OK |
CalledNBR:    |       5 |       |      OK |
LOC:          |       8 |       |      OK |
metrics are OK
Clone analysis:
This file has 1 potentially cloned functions:
  do_text
In raster/r.report/maskinfo.c clones of  do_text are:
	raster/r.info/reclas_txt.c  do_text
Threshold GRASS6 key metrics values at 2007-04-15 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      87 |
LOC:                    43 |       195 |     272 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
