[GRASS-QA] GRASS QA: glynn | ./grass6/raster/r.li/r.li.daemon/worker.c |no clones | 0 monsters | 1 warnings
Sun Apr 15 17:35:30 EDT 2007
Hello glynn,
ANALYSIS
raster/r.li/r.li.daemon/worker.c functions
worker (Begins at: 39 Ends at: 214)
Complexity:   |      20 |     * |         |
ParamNBR:     |       9 |   *** | MONSTER |
CalledNBR:    |      46 |     * |         |
LOC:          |     176 |     * |         |
at least 1 values are close to an outlier please consider revising code
mask_preprocessing (Begins at: 216 Ends at: 253)
Complexity:   |       4 |       |      OK |
ParamNBR:     |       4 |       |      OK |
CalledNBR:    |      15 |       |      OK |
LOC:          |      38 |       |      OK |
metrics are OK
RLI_get_cell_raster_row (Begins at: 255 Ends at: 267)
Complexity:   |       2 |       |      OK |
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |       1 |       |      OK |
LOC:          |      13 |       |      OK |
metrics are OK
RLI_get_dcell_raster_row (Begins at: 269 Ends at: 281)
LOC:          |      13 |       |      OK |
metrics are OK
RLI_get_fcell_raster_row (Begins at: 283 Ends at: 295)
LOC:          |      13 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-04-15 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      87 |
LOC:                    43 |       195 |     272 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
