[GRASS-QA] GRASS QA: glynn | ./grass6/lib/gis/file_name.c |no clones | 0 monsters | 0 warnings
Sun Apr 15 23:22:19 EDT 2007
Hello glynn,
ANALYSIS
lib/gis/file_name.c functions
G__file_name (Begins at: 23 Ends at: 64)
Complexity:   |       5 |       |      OK |
ParamNBR:     |       4 |       |      OK |
CalledNBR:    |      11 |       |      OK |
LOC:          |      42 |       |      OK |
metrics are OK
G__file_name_misc (Begins at: 66 Ends at: 114)
Complexity:   |       6 |       |      OK |
ParamNBR:     |       5 |     * |         |
CalledNBR:    |      13 |       |      OK |
LOC:          |      49 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-04-15 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      87 |
LOC:                    43 |       195 |     272 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
