[GRASS-QA] GRASS QA: glynn | ./grass6/raster/r.support/front/front.c |no clones | 1 monsters | 0 warnings
Sun Apr 15 23:22:20 EDT 2007
Hello glynn,
ANALYSIS
raster/r.support/front/front.c functions
main (Begins at: 33 Ends at: 282)
Complexity:   |      25 |     * |         |
CalledNBR:    |     127 |   *** | MONSTER |
LOC:          |     250 |    ** | Warning |
1 metric are OUT OF RANGE!
Clone analysis:
Threshold GRASS6 key metrics values at 2007-04-15 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      87 |
LOC:                    43 |       195 |     272 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
