[GRASS-QA] GRASS QA: glynn | ./grass6/raster/r.fill.dir/filldir.c |no clones | 0 monsters | 0 warnings
Mon Apr 16 16:44:20 EDT 2007
Hello glynn,
ANALYSIS
raster/r.fill.dir/filldir.c functions
check (Begins at: 11 Ends at: 37)
Complexity:   |       4 |       |      OK |
ParamNBR:     |       6 |     * |         |
CalledNBR:    |       2 |       |      OK |
LOC:          |      27 |       |      OK |
metrics are OK
fill_row (Begins at: 40 Ends at: 79)
Complexity:   |       3 |       |      OK |
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |      15 |       |      OK |
LOC:          |      40 |       |      OK |
metrics are OK
build_one_row (Begins at: 82 Ends at: 146)
Complexity:   |       8 |       |      OK |
ParamNBR:     |       5 |     * |         |
CalledNBR:    |      14 |       |      OK |
LOC:          |      65 |       |      OK |
metrics are OK
filldir (Begins at: 148 Ends at: 196)
ParamNBR:     |       4 |       |      OK |
CalledNBR:    |      23 |       |      OK |
LOC:          |      49 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-04-16 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      87 |
LOC:                    43 |       195 |     272 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
