[GRASS-QA] GRASS QA: hamish | ./grass6/display/d.paint.labels/do_labels.c |no clones | 1 monsters | 0 warnings
Mon Apr 16 23:36:01 EDT 2007
Hello hamish,
ANALYSIS
display/d.paint.labels/do_labels.c functions
initialize_options (Begins at: 44 Ends at: 65)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       5 |       |      OK |
LOC:          |      22 |       |      OK |
metrics are OK
do_labels (Begins at: 68 Ends at: 155)
Complexity:   |      25 |     * |         |
CalledNBR:    |      47 |     * |         |
LOC:          |      88 |       |      OK |
metrics are OK
show_it (Begins at: 157 Ends at: 433)
Complexity:   |      28 |    ** | Warning |
CalledNBR:    |      54 |     * |         |
LOC:          |     277 |   *** | MONSTER |
1 metric are OUT OF RANGE!
scan_ref (Begins at: 437 Ends at: 459)
Complexity:   |       8 |       |      OK |
LOC:          |      23 |       |      OK |
metrics are OK
xmatch (Begins at: 461 Ends at: 477)
Complexity:   |       6 |       |      OK |
CalledNBR:    |       4 |       |      OK |
LOC:          |      17 |       |      OK |
metrics are OK
ymatch (Begins at: 479 Ends at: 499)
CalledNBR:    |       6 |       |      OK |
LOC:          |      21 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-04-16 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      87 |
LOC:                    43 |       195 |     272 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
