[GRASS-QA] GRASS QA: markus | ./grass6/lib/gis/make_loc.c |no clones | 0 monsters | 0 warnings
Thu Apr 19 09:38:20 EDT 2007
Hello markus,
ANALYSIS
lib/gis/make_loc.c functions
G__make_location (Begins at: 43 Ends at: 125)
Complexity:   |       7 |       |      OK |
ParamNBR:     |       5 |     * |         |
CalledNBR:    |      14 |       |      OK |
LOC:          |      83 |       |      OK |
metrics are OK
G_make_location (Begins at: 127 Ends at: 169)
Complexity:   |       3 |       |      OK |
CalledNBR:    |       3 |       |      OK |
LOC:          |      43 |       |      OK |
metrics are OK
G_compare_projections (Begins at: 172 Ends at: 276)
Complexity:   |      15 |       |      OK |
ParamNBR:     |       4 |       |      OK |
CalledNBR:    |      33 |       |      OK |
LOC:          |     105 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-04-19 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      87 |
LOC:                    43 |       195 |     273 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
