[GRASS-QA] GRASS QA: glynn | ./grass6/lib/datetime/type.c |no clones | 0 monsters | 0 warnings
Thu Apr 19 19:33:40 EDT 2007
Hello glynn,
ANALYSIS
lib/datetime/type.c functions
datetime_set_type (Begins at: 38 Ends at: 56)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       5 |     * |         |
CalledNBR:    |       2 |       |      OK |
LOC:          |      19 |       |      OK |
metrics are OK
datetime_get_type (Begins at: 59 Ends at: 78)
CalledNBR:    |       1 |       |      OK |
LOC:          |      20 |       |      OK |
metrics are OK
datetime_is_valid_type (Begins at: 81 Ends at: 115)
ParamNBR:     |       1 |       |      OK |
LOC:          |      35 |       |      OK |
metrics are OK
datetime_check_type (Begins at: 118 Ends at: 152)
Complexity:   |      13 |       |      OK |
CalledNBR:    |      14 |       |      OK |
LOC:          |      35 |       |      OK |
metrics are OK
datetime_in_interval_year_month (Begins at: 155 Ends at: 158)
LOC:          |       4 |       |      OK |
metrics are OK
datetime_in_interval_day_second (Begins at: 161 Ends at: 176)
LOC:          |      16 |       |      OK |
metrics are OK
datetime_is_absolute (Begins at: 179 Ends at: 194)
CalledNBR:    |       0 |       |      OK |
LOC:          |      16 |       |      OK |
metrics are OK
datetime_is_relative (Begins at: 197 Ends at: 200)
LOC:          |       4 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-04-19 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      87 |
LOC:                    43 |       195 |     273 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
