[GRASS-QA] GRASS QA: glynn | ./grass6/lib/datetime/incr1.c |no clones | 1 monsters | 0 warnings
Thu Apr 19 19:33:40 EDT 2007
Hello glynn,
ANALYSIS
lib/datetime/incr1.c functions
datetime_increment (Begins at: 67 Ends at: 154)
Complexity:   |       7 |       |      OK |
CalledNBR:    |      13 |       |      OK |
LOC:          |      88 |       |      OK |
metrics are OK
_datetime_subtract_field (Begins at: 156 Ends at: 373)
Complexity:   |      41 |   *** | MONSTER |
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |      28 |       |      OK |
LOC:          |     218 |    ** | Warning |
1 metric are OUT OF RANGE!
_datetime_carry (Begins at: 380 Ends at: 468)
Complexity:   |      20 |     * |         |
CalledNBR:    |       2 |       |      OK |
LOC:          |      89 |       |      OK |
metrics are OK
_datetime_add_field (Begins at: 470 Ends at: 498)
Complexity:   |       9 |       |      OK |
LOC:          |      29 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-04-19 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      87 |
LOC:                    43 |       195 |     273 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
