[GRASS-QA] GRASS QA: glynn | ./grass6/raster/r.patch/main.c |no clones | 0 monsters | 1 warnings
Fri Apr 20 13:58:10 EDT 2007
Hello glynn,
ANALYSIS
raster/r.patch/main.c functions
main (Begins at: 23 Ends at: 207)
Complexity:   |      17 |     * |         |
CalledNBR:    |      64 |    ** | Warning |
LOC:          |     185 |     * |         |
at least 1 values are close to an outlier please consider revising code
Clone analysis:
Threshold GRASS6 key metrics values at 2007-04-20 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      87 |
LOC:                    43 |       195 |     273 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
