[GRASS-QA] GRASS QA: glynn | ./grass6/lib/display/symbol.c |no clones | 0 monsters | 0 warnings
Sun Apr 22 03:18:50 EDT 2007
Hello glynn,
ANALYSIS
lib/display/symbol.c functions
D_symbol (Begins at: 40 Ends at: 124)
Complexity:   |      12 |       |      OK |
ParamNBR:     |       5 |     * |         |
CalledNBR:    |      16 |       |      OK |
LOC:          |      85 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-04-22 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      87 |
LOC:                    43 |       195 |     273 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
