[GRASS-QA] GRASS QA: hamish | ./grass6/display/d.graph/do_graph.c |no clones | 0 monsters | 0 warnings
Thu Apr 26 09:09:28 EDT 2007
Hello hamish,
ANALYSIS
display/d.graph/do_graph.c functions
set_graph_stuff (Begins at: 25 Ends at: 35)
Complexity:   |       3 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       0 |       |      OK |
LOC:          |      11 |       |      OK |
metrics are OK
set_text_size (Begins at: 37 Ends at: 49)
Complexity:   |       2 |       |      OK |
CalledNBR:    |       2 |       |      OK |
LOC:          |      13 |       |      OK |
metrics are OK
do_draw (Begins at: 51 Ends at: 77)
Complexity:   |       4 |       |      OK |
CalledNBR:    |       7 |       |      OK |
LOC:          |      27 |       |      OK |
metrics are OK
do_move (Begins at: 79 Ends at: 97)
LOC:          |      19 |       |      OK |
metrics are OK
do_color (Begins at: 99 Ends at: 129)
Complexity:   |       5 |       |      OK |
CalledNBR:    |      11 |       |      OK |
LOC:          |      31 |       |      OK |
metrics are OK
do_linewidth (Begins at: 131 Ends at: 144)
CalledNBR:    |       5 |       |      OK |
LOC:          |      14 |       |      OK |
metrics are OK
do_poly (Begins at: 147 Ends at: 204)
Complexity:   |       9 |       |      OK |
LOC:          |      58 |       |      OK |
metrics are OK
do_size (Begins at: 206 Ends at: 232)
LOC:          |      27 |       |      OK |
metrics are OK
do_rotate (Begins at: 234 Ends at: 245)
LOC:          |      12 |       |      OK |
metrics are OK
do_text (Begins at: 247 Ends at: 258)
Complexity:   |       1 |       |      OK |
CalledNBR:    |       1 |       |      OK |
LOC:          |      12 |       |      OK |
metrics are OK
check_alloc (Begins at: 260 Ends at: 293)
CalledNBR:    |       4 |       |      OK |
LOC:          |      34 |       |      OK |
metrics are OK
do_icon (Begins at: 295 Ends at: 345)
CalledNBR:    |      18 |       |      OK |
LOC:          |      51 |       |      OK |
metrics are OK
do_symbol (Begins at: 347 Ends at: 444)
Complexity:   |      11 |       |      OK |
CalledNBR:    |      34 |       |      OK |
LOC:          |      98 |       |      OK |
metrics are OK
set_last_color (Begins at: 447 Ends at: 459)
ParamNBR:     |       4 |       |      OK |
LOC:          |      13 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-04-26 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      87 |
LOC:                    43 |       195 |     273 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
