[GRASS-QA] GRASS QA: scott | ./grass6/lib/db/dbmi_driver/driver.c |no clones | 0 monsters | 0 warnings
Thu Apr 26 13:28:09 EDT 2007
Hello scott,
ANALYSIS
lib/db/dbmi_driver/driver.c functions
db_driver (Begins at: 40 Ends at: 170)
Complexity:   |      13 |       |      OK |
CalledNBR:    |      39 |     * |         |
LOC:          |     131 |     * |         |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-04-26 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      87 |
LOC:                    43 |       195 |     273 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
