[GRASS-QA] GRASS QA: carlos | ./grass6/raster/r.contour/main.c |no clones | 0 monsters | 1 warnings
Fri Aug 10 10:46:11 EDT 2007
Hello carlos,
ANALYSIS
raster/r.contour/main.c functions
main (Begins at: 52 Ends at: 223)
Complexity:   |      12 |       |      OK |
CalledNBR:    |      78 |    ** | Warning |
LOC:          |     172 |     * |         |
at least 1 values are close to an outlier please consider revising code
get_z_array (Begins at: 226 Ends at: 243)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |       6 |       |      OK |
LOC:          |      18 |       |      OK |
metrics are OK
getlevels (Begins at: 247 Ends at: 343)
Complexity:   |       9 |       |      OK |
ParamNBR:     |       6 |     * |         |
CalledNBR:    |      22 |       |      OK |
LOC:          |      97 |       |      OK |
metrics are OK
displaceMatrix (Begins at: 351 Ends at: 374)
Complexity:   |       2 |       |      OK |
ParamNBR:     |       5 |     * |         |
CalledNBR:    |       3 |       |      OK |
LOC:          |      24 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-08-10 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      88 |
LOC:                    43 |       195 |     272 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
